What combo to go with
I want to know also. If so, springs here I come. Also what about the rockers will the increase performance/ hp?
Originally Posted by Tiburon
Is it possible 15-20 hp from a valve spring?
You will see 15-20 HP typical from a good set of springs. It has to do with a combination of better spring harmonics, better stability at higher RPM, and the increased pressure will stabalize the valvetrain. The better spring harmonics get you more power because the engine will have less "bad harmonics" to power through. These are RPM's where the spring stops functioning and just sort of dances on the head. Normally they don't last very long, but can happen at several times in the full RPM range of an engine.
Another issue on the LS-1 is that going to a good dual spring eliminates the "meshing" noise that bee-hive or conical springs cause. This is when one of the smaller coils smashes into one of the larger ones. This creates a "knocking" or "meshing" noise that trips the knock sensor in the engine and pulls timing out of the motor.
A good roller rocker will also give you more power because of smoother movement of the rocker with a better roller fulcrum, and with an increase in ratio. With the increase in ratio, it'd be just like putting a bigger cam in.
Several companies have good dual spring/retainer combos in your price range. When you go to do the cam and/or rockers, better springs open up more options to what you can do.
hmm, good info
so what if your not runnin a high lift cam like a .529
would it be worth it to go get double springs then, or should you stick with singles like ls6 springs or comp 918's?
Originally Posted by BigTex
Go ahead and do the cam. I'm pretty sure you should be able to find a used comp 212/218 and springs for $250. Ive seen several go for less. Linenfelter sold one on ebay recently for around $170.
Thanks,
Andrew
