What cam and roller rockers?
Old Feb 15, 2003 | 02:35 PM
Default What cam and roller rockers?
Im going into the cam market with my tax refund. Id like to do a cam. springs/roller rockers. I also run a magnacharged 5.3l. Any suggestions???
Old Feb 15, 2003 | 02:42 PM
GREGGO's Avatar
Default Re: What cam and roller rockers?
For a blower cam, I won't be able to make a good suggestion. For the springs, I would go with Manly double springs, but you will have to pull the heads to do that due to the spring base being larger. If the cam is not to wild (under 550 lift) you could get by with Comp 918's. Roller rockers, I wouldn't evn spend my mony on. We already have a roller setup that is 1.7. Most 10 sec F-bodies use the stock rollers.
Greg
Old Feb 15, 2003 | 10:33 PM
Thank you greg, i was wondering what ours were. 1.7 is damn good, considering the 1.8s are $699 from summit.
Old Feb 16, 2003 | 10:08 AM
Patrick G's Avatar
LS1 Tech Administrator
Keep the stock rockers and go with the cam only. Widen the lobe separation angle a little (compared to your typical N/A cam). 212/218, 116 LSA would work nice. Running a blower means you don't need to go crazy on the intake duration, but it means you'll still need to open the exhaust long enough to get it out. If you were running N/A with headers, I might recommend a 216/216, 113 cam, but with a blower, the choices are different.
Old Feb 16, 2003 | 10:29 AM
parish8's Avatar
single digit dreamer
are you going to get a before and after dyno? i would really like to know what a 212/218 116lsa does with a blower like ours. i have been thinking about a cam for a long time but just can't decide wich one and no one can really say that it will make a diference.
DrX
Aug 19, 2015 04:45 PM
Hmguyton
Aug 9, 2015 05:38 PM
BigEd_72455
Aug 8, 2015 07:37 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
supersportsteve
Jul 4, 2015 12:02 PM
