what cam with radix s/c
Old Jan 3, 2004 | 11:31 AM
1Blown04's Avatar
Default what cam with radix s/c
my dad recently put radix s/c on his 03 silverado ss and was trying to figure out what cam would work best with that setup, i searched and havent found many options but a small comp cam and the 02 ls6 cam. does anyone have have specs for the cam that lingenfelter or 20th century use for their packages. any info would be appreciated
thanks
by the way it also has a volant cai, dyantech flp headers w/ high flow cats and a corsa catback.
Old Jan 3, 2004 | 01:29 PM
FILE's Avatar
Something not too agresive with a lobe sep angle of no less than 114. Anything lower and it will probably bleed off cylinder preasure and as a result will not cause optimal boost.
Old Jan 3, 2004 | 03:49 PM
Flyer's Avatar
216/224 .524/.534 on a 114 or 115 would be a sweet cam for that. Maybe a bit more lift though. something like 544/554 or something. Just to let more air in. That would move the rpm range up some though. As stated CompCams says that cam is good from 1500 to 6000 recommending a higher stall converter too. Something like a 2600-3000 would be optimal.
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
therock
Jul 25, 2015 09:23 AM
projectnightcrawler
Jul 19, 2015 11:30 PM
sTNT971
Jul 16, 2015 12:39 PM
