What cam
Old Aug 5, 2002 | 06:20 AM
Default What cam
Ive decided i need a little more power. I dont want to spend major$$$ on heads and i want something that will run well with the magna. after that, its going to the dyno for some tuning. What cam fits in the 5.3L??????
Old Aug 5, 2002 | 01:28 PM
hihosilver's Avatar
Default Re: What cam
any ls1 cam, i'm thinking of going with a 224/221 .050 .558/.558 111 LSA cam...that's as far as i figure i can go without computer work. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Aug 5, 2002 | 01:33 PM
RED2K's Avatar
HIHO..... i think you might have to have some tuning with that kind of duration. that is what the guy at street chips in tulsa told me anyway. that is a healthy cam
Old Aug 5, 2002 | 01:39 PM
hihosilver's Avatar
with that cam it should run good, but idle quality should drop just a little bit...nothing major though.
Old Aug 5, 2002 | 03:24 PM
GREGGO's Avatar
218/218 563/563 112lsa cam
That is what I'm planning with the 5.3 buid up.
Greg
Old Aug 5, 2002 | 06:02 PM
BigKID's Avatar
Wouldn't something with a split duration do better with the supercharger?
Old Aug 5, 2002 | 06:09 PM
im pretty unfamiliar with the inside of the 5.3. what else can i replace to pick up more power along with the cam? What about valve springs from the vette? Any suggestions.
Old Aug 6, 2002 | 07:37 AM
BigKID's Avatar
If you go with a cam with over .500 lift, you are going to have to change the valve springs. The stock springs will not handle that much lift.
Old Aug 23, 2002 | 08:52 PM
cadyman's Avatar
that ls1 cam is not a good choice for a truck no low end torque
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
