what am i missing, comments on new setup
im looking for comments on the setup im building for a 2000 rcsb 4x4. just making sure im not missing anything. stock its a 5.3 auto, going to...
00 6.0 lq4
799 heads
thunder racing tr224 on 114lsa dual valvesprings retainers hardened seats, pushrods and locks
ls1 fans- nelson harness
pacesetter lt coated
probobly a nelson tune for now
question will the stock 6.0 injectors be enough?
00 6.0 lq4
799 heads
The radiator is going on 9 years old now and you live in Arizona. I'd look into the '05 fans and the 35" radiator swap instead of the stock 28" radiator with LS1 fans. Just a suggestion.
I second the 42-43lb injectors as well. Injectors are like Goldy Locks and the Three Bears. You don't want injectors that are so big they're flooding the cylinders with too much fuel at idle, but at the same time you don't want to run out of fuel with over 90% duty cycle at WOT. You want just the right size.
The 99-00 6.0 do have a longer crank and won't work on a 4l60e, l80e yes. Also they have iron head. I would look for a 01 up 6.0, save alot of headaches. Also find you some 42-44lb injectors..
John
John
Grrrr I cant win. I already have the block, and was planning on using the 60 for the winter then a 80 swap in the spring. Looks like I will be doing it now. Any specific year 4l80 to get? And any links to swap info? The one on ls1 truck makes it look overly complicated, is it really that bad? Thanks
And to answer one of your original questions, look at hirdlej's 6.0L swap thread going on. He just swapped out the stock 6.0 injectors because they were borderline not enough. You may get by with your combo, but it's unlikely.
Too late, I bought a 4l80e yesterday out of a 02. I figure the 4l60 will always be a weak link so ill bite the bullet and swap it now...Well see how that goes. Now Im working on the part list for the swap.
