What about this cam?
Exactly, and there is absolutely no evidence to support the claim that more lift= more horsepower on our heads(753's or whever the 4.8/5.3L heads are called). Of course if you have worked heads that would be different. There are plenty of flow charts to prove my point too.
been reading alot of hitmans posts huh?
sure it wont flow any more past 500 but it will stay above 500 for longer to get max air in. i picked up 7/10 with my cam. .587 lift. this can be argued all day. the heads "Fagged out" at 500 which is how ive heard it put, why do cam companies make dozens of off the shelf cams with high lift if it doesnt work.
heres a way of looking at it. you can breathe through your mouth just fine when its wide open, but if its only wide open for a split second you wont get as much air in as you want.
