well i did it
Old Aug 26, 2009 | 07:52 PM
lablackbeast's Avatar
doesn't know what quit means
Default well i did it
i change the 1 3/4 pace headers for 1 7/8 ARH man it was a night and day difference well on me it was cause my exhaust ports were bigger than the header port so it was a ristriction for the motor well my set up is a 6.2 with p&p heads milled and full bolt ons and also a custon grind cam..... i notice that the trucks goes spinning 1st and second with this simple swap on D from a 30 roll which it didnt use to do that it did but i would have to drop it to first and it will do it............ also one of the spark plugs is chipped bad and its missfiring pretty bad see if i change it soon......................
Old Aug 26, 2009 | 07:59 PM
GMCtrk's Avatar
dang...I believe you are the first to report the change from 1 3/4 to 1 7/8. Also, the ARH has a much better collector. Ive seen a report on an SBC that gained 12 hp going to a good merge collector over a standard collector. Do you think you gained any highway cruising power with the switch?
Old Aug 26, 2009 | 08:01 PM
GMCtrk's Avatar
also do you get ticking sound inside the cab
Old Aug 26, 2009 | 08:11 PM
well by the collector do you mean the piece that you bolt on and weld??? if so na i just welded it to the header and i havent droven it in the highway........ what you mean by ticking noise????
Old Aug 26, 2009 | 08:13 PM
GMCtrk's Avatar
I always got a wicked pinging/ticking noise in the cab at high load in 4th. Supersub says he gets it as well with his 1 7/8 ARH's and it bugs the heck out of him.
Old Aug 26, 2009 | 08:38 PM
na well i will see tomorrow see if it do
Old Aug 26, 2009 | 08:39 PM
GMCtrk's Avatar
you must have just got them installed
Old Aug 26, 2009 | 08:49 PM
yes i did feels way better and that spark plug **** should be **king me up or what you think???
Old Aug 26, 2009 | 08:57 PM
GMCtrk's Avatar
is a SES flashing?
Old Aug 26, 2009 | 08:58 PM
the check engine light is on.........
