Well, here we go again!!
Old Apr 6, 2005 | 10:03 PM
closet red neck's Avatar
Question Well, here we go again!!
Does the stock intake on the 5.3 need to be replaced, with all my modes in my sig and the following? I will be installing a cam, lifters, pushrods, springs, AFR heads, going to a 1.85 roller rocker and possibly a s/c, blower, turbo.......what do ya'll think!! Ya'lls opinion's and input are greatly respected and appreciated!!!!!!
Old Apr 6, 2005 | 10:11 PM
one03sierra's Avatar
Formerly one92rs
Talking
no. it will pull more torque than the others.
Old Apr 6, 2005 | 10:18 PM
BlownChevy's Avatar
blownerator
25 Year Member
No need, save your money
Old Apr 6, 2005 | 10:19 PM
Even as much or more than a FAST intake???????? I'm just asking, trying to figure this out!!!
Old Apr 6, 2005 | 10:21 PM
BlownChevy's Avatar
blownerator
25 Year Member
The gains will be negligible at best....and you will need more than an intake to make it work
Old Apr 6, 2005 | 10:24 PM
99Silver6.0's Avatar
The FAST will make more peak. Not sure about the grunt area. Youd have to get an LSX and a 90MM TB. They aint cheap. Keep the truck intake man.
Old Apr 6, 2005 | 10:30 PM
Not trying to be smartass but could you elaborate some, please.?.?.
Old Apr 7, 2005 | 12:17 AM
02sierraz71_5.3's Avatar
In will hendzels book they used one the fast intakes on a 5.3 setup check it out its a great book.
Old Apr 7, 2005 | 06:01 AM
Formerly one92rs
Talking
the truck intake made as much hp till 5500rpm's as the fast and the ls1 and ls6. above the 5000 and 6000rpm levels the others made more but it was minmal as to the torque that the truck intake generated. the truck intake actually had a better torque and hp curve. being as these trucks are bricks i think the truck intake is best for our application.
you will need to make some spacers-get an idler pulley relocater bracket-cut the water pump. prolly a few other mods. i have pondered this swap so many times just to find out. i think i still might do it.
Old Apr 7, 2005 | 08:36 AM
ktmrider's Avatar
The LSx and LS1/6 intakes require lots of mods to the belt/pulley system as the non truck models are lower and cause the TB to interfere. It also requires the car style waterpump ( the return hose is up on the truck vs forward on the car again for clearance ).
There is another post on here for a idler pulley relocator for the trucks using the car intake.
In the end, the others are exactly right. You will gain some hp/trq above 5000rpm but lose below that. For our big rolling bricks low end torque is better IMHO.
