Weird idle
Old Jan 4, 2005 | 12:16 AM
GREGGO's Avatar
Originally Posted by BlownChevy
The one below it is the TPS.
That would be the throttle position sensor. We really need to make a list of these abreviations. I know there is one around somewhere.
Old Jan 4, 2005 | 12:19 AM
BlownChevy's Avatar
blownerator
25 Year Member
Good idea HHDDB
Old Jan 4, 2005 | 12:23 AM
GREGGO's Avatar
Good idea HHDDB
That's not on the list. WHat is it? Looks like we need to add some.
https://ls1tech.com/acronyms.html
Old Jan 4, 2005 | 01:09 AM
BlownChevy's Avatar
blownerator
25 Year Member
Grippy will fill you in in hhddb. He has been saying it for a while now, and I finally asked him WTF it means.
Old Jan 4, 2005 | 10:09 AM
user 108208932024's Avatar
Banned
I just checked out the IAC motor on the top right of the TB, it is held in by the torx screws like you said and there are wires that plug into the right side of it, how do I check for carbon build up and would it be safe to spray carb cleaner in it?
Old Jan 4, 2005 | 05:36 PM
KeukaZ71's Avatar
i had the same problem as you. except there were times where my truck would completely stall out. i clean the idle air control valve and it works better now.
- disconnect the plug from the IAC
- take the 2 torx screws out (kind of tricky)
- pull out the IAC (but do not push the plastic black part in)
- i cleaned the black plastic part (pintle) with carb cleaner and a clean rag/toothbrush. do not immerse it in cleaning solution
- also clean part of the TB where the IAC came from
- then put the IAC back on, careful not to disturb the pintle
hope this helps
Old Jan 4, 2005 | 06:56 PM
hink9's Avatar
while youre there clean the whole t/b especially the idle compensation hole in the t.b blades. if that doesnt work, i think there a reprogram from gm about this. it may be elec. throttle only though.
Old Jan 4, 2005 | 06:58 PM
Banned
Thanks, I was going to do it today but got busy, I will try this tommorow, how do you get the torx screws out without a torx set? What is the worst that can happen if I screw up? Also my truck dips to like 200 or 300 RPM when I put it in drive when it's having these problems. Hopefully this will fix it.
Old Jan 4, 2005 | 08:09 PM
KeukaZ71's Avatar
the rpms should drop when put in gear, but i am not sure how much. 300 sounds like a bit too much.
the best thing to do is remove the whole entire TB, therefore, it should make it easier to unscrew the IAC, plus you can clean the rest of the TB.
i didn't have the time to undo the TB so here is what i did. i had to use a 1/4" rachet with a deep socket, and in the end of the deep socket i put a torx bit. it was a PITA because i kept dropping screws into the engine bay somewhere. it would of been easier to remove the whole TB
Old Jan 4, 2005 | 08:46 PM
Banned
Yeah I know it will drop a little bit but this is like 100 RPM's away from stalling it seems like.
Thanks for all your info.
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
BlownHD
Oct 3, 2015 12:24 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
01silvy
Sep 26, 2015 10:20 PM
