Waterpump: 1.88" Thermostat outlet or 2.05" outlet?
Old Apr 15, 2013 | 03:07 PM
RandomHero's Avatar
Default Waterpump: 1.88" Thermostat outlet or 2.05" outlet?
Hey guys, I'm fixing to put a new waterpump on my truck since the stocker seems to be leaking.
Looking online it seems there are pumps with a 1.88" thermostat outlet and some with a 2.05" outlet.
My truck is a 1999 silverado ext cab lt 2wd with the 5.3L.
The obvious answer is that, I should measure the outlet myself, but I don't have the ability to pull it and then go buy the part. If anyone knows which one I need, I'd greatly appreicate it.
Old Apr 17, 2013 | 09:25 AM
RandomHero's Avatar
Any help with this? I'm debating on buying both and returning the one that doesn't fit, but this would save that trouble.
Old Jun 24, 2014 | 06:40 AM
tashspop's Avatar
i'm looking for the same answer. i just recently replaced my thermostat and at first got the one piece design which would not fit in my housing (too big). the two piece fit in there which was great because it was cheaper. i'm reading that 04-up Gm switched to a two piece thermostat/housing. i want to confirm size before i order a new pump although from my experience i'm guessing the two piece design is the smaller 1.88" outlet. i measured the size of the one piece thermostat to confirm it was larger than my original and it was right at 2".
kha4079
Oct 29, 2018 04:38 PM
simman22
Jan 21, 2017 10:27 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
gavin2005
Sep 13, 2015 09:04 PM
gmcyukon
Sep 7, 2015 08:46 PM
