Water pump help
Old Apr 25, 2022 | 07:02 PM
1970hemicuda's Avatar
Default Water pump help
So currently tearing down my engine for a cam swap. It's a jeep Comanche with a L33 swap. Im using a ICT front accessory mount kit. It uses a LS1 water pump with spacers to align the truck dampener and accessories. The truck water pumps outlet would not work with my ls6 intake. Everything is very tight and while seeing if I could work something out I found that the L99 Camaro's water pump is the same spacing as a truck for everything? Water outlet would actually work better for me too. And also this would mean I could get rid of the spacers that I have to use. I just wanted to confirm that this is correct. Thanks.
EDIT
After really looking at the way my brackets are set up I don't think the Camaro pump is going to work. Might try a whole different set up.
Old Apr 25, 2022 | 07:11 PM
wretched73's Avatar
https://www.ictbillet.com/swap-guide...e.html#cat-557
Looks like LS3 Camaro water pump will work. I don't know if that is the same as the L99 pump.
Apr 6, 2014 05:06 PM
joelm86
Jan 19, 2014 03:37 AM
themodernartist
Jun 28, 2009 08:37 AM
redLS1rado
Apr 18, 2005 08:24 PM
ohohsilverado
Sep 27, 2004 09:56 PM
