Water Pump
Old Apr 11, 2007 | 10:02 AM
zippy's Avatar
Default Water Pump for car intake
I have two trucks I'm working on getting parts for car intakes and in the process of trying to get the correct 97' Corvette water pump I ran accross another possible solution and plan to try it out later if time permits. For those of you who might have access to it right now, check it out. The water pump from an 07' GMT900 (NBS) looks like it might work with a car intake and yet have the pulley system for a truck. Take a look.
Old Apr 11, 2007 | 10:19 AM
mwalls54's Avatar
Need More N2O Mod
From the pictures it looks like it might fit, The only thing would be which throttle body is used.
Old Apr 11, 2007 | 11:26 AM
tdrumm's Avatar
In one of the older LS6 intake manifold swap threads, Speartech said that they were able to use the new truck water pump for a LS6 conversion only on trucks with cable driven TBs. It still won't clear the DBWs.
Old Apr 11, 2007 | 11:36 AM
zippy's Avatar
Interesting, that must have been a post I'd missed. I am planning to try to see how it fill fit on an L76 setup with car intake when I get home.
Old Apr 11, 2007 | 11:39 AM
zippy's Avatar
Interesting, that must have been a post I'd missed. I am planning to try to see how it fill fit on an L76 setup with car intake when I get home. Kind of interesting if anything. I wonder if I'm just that late in noticing this...
Old Apr 11, 2007 | 11:56 AM
OnyxSilveradoSS's Avatar
I knew you would be working on this!
Please keep us updated-I bet a bunch of SSS guys will want this, I am one of them!
Do you have any ideas about what throttle body you will use? or is there a way to chane from the stock drive b wire to a TBSS DBW unit???
Old Apr 11, 2007 | 11:57 AM
bluecajun5.3's Avatar
11 Second Truck Club
i seen that post also.
Old Apr 11, 2007 | 01:14 PM
zippy's Avatar
Old Apr 11, 2007 | 01:27 PM
mwalls54's Avatar
Need More N2O Mod
Ok zippy we heard you the 1st time.
Old Apr 11, 2007 | 03:17 PM
zippy's Avatar
I have no idea what happened. It took about 10 minutes for the post to go through and yet I only clicked reply the one time . One of the mods can delete that for me if possible.
