warped header flange
Old Jan 14, 2014 | 10:36 AM
joshua022's Avatar
Default warped header flange
How can I fix my warped header flange? Ive thought about trying to use the bolts to pull it in but with it being an aluminum head, I wasn't so sure.
thoughts?
Old Jan 14, 2014 | 10:43 AM
Atomic's Avatar
I have a gauge for that
Have it surfaced or put it on a belt sander.
My turbo flange is warped but I just use the bolts to pull it in...
Old Jan 14, 2014 | 10:55 AM
joshua022's Avatar
I was thinking of bolting them to the old manifolds and heating the flange while tightening the bolts to see if that helps
Old Jan 14, 2014 | 11:01 AM
Koots's Avatar
I used a big, flat file to get the warps out, then surfaced it with a belt sander-like machine in my shop (no longer there, as it died).
Old Jan 15, 2014 | 07:40 PM
SCREAMINXL's Avatar
I thought you had ARP exhaust studs? If so that would work a lot better than bolts.
I use a large belt sander at a local metal fabrication shop.
Old Jan 15, 2014 | 08:54 PM
Atomic's Avatar
I do, but it warped so bad I had to hammer it off ruining the threads on a couple, so I have mostly studs and 2 bolts
Old Jan 15, 2014 | 09:58 PM
SCREAMINXL's Avatar
haha! Can't complain if it works! Those studs are expensive......... and I want a set.
kha4079
Oct 29, 2018 04:38 PM
Velocity1
Oct 12, 2015 10:39 PM
Superman09
Sep 25, 2015 05:55 AM
5.3lSilverado
Sep 20, 2015 06:48 PM
