want more power 8.1
Old Nov 4, 2004 | 07:32 AM
TieRod's Avatar
What size cam are you using? Just curious I'm going to run Raylar biggest cam. I've been waiting on Ray to get my heads and intake to me. Its getting old in a hurry especially when I need this truck for the snow.
Old Nov 4, 2004 | 06:49 PM
8.1 HD's Avatar
running 8.5lbs right now going to go more eventually....how hard was the tranny swap??
Old Nov 4, 2004 | 08:12 PM
ChevySSandChevy8.1's Avatar
I'm running a COMP cam shaft of 218/224 510/.510 114. Hows the Raylar cams, I bought the COMP because it was on sale and they're generally cheaper. So are you changing up to the BP-106 from Raylar?, which intake did you go with, did you change the whole intake manifold?
...8.1HD... The 4180E trans swap went smooth, not a hard swap, i'd get either a yank torque converter with it. What kind of mileage are you guys getting with your 8.1?
Old Nov 4, 2004 | 08:18 PM
8.1 HD's Avatar
Getting 12.5mpg running unloaded @75mph, around town 10mpg...towing 8mpg @75mph..could be worse... oh and thats running 35's and a 3.73 rear.....contemplating going to 4.56's
Old Nov 5, 2004 | 08:24 PM
TieRod's Avatar
Yea that the one I'm going to run, it was ground by crane I don't have the came card handy but I do remember it has .610/.621 114 and it power range is from 3000-6600rpm. I'm using Raylar's intake manifold and I'm going to plume it with a fogger system.
Old Nov 5, 2004 | 11:17 PM
thats pretty good mileage your getting, the 4.56 will definately change that. ...tie rod... thats sounding like a pretty good setup, is your truck running the raylar pistons yet? Do you have a custom PCM tune? does your truck drink a bout a quart of oil every 4000 miles?
Old Nov 6, 2004 | 02:33 AM
TieRod's Avatar
I will be running Raylar pistons but my truck is down right now do to the stock pistons. I've been waiting for Raylar to get there stroker cranks done but the manufacture kept pushing back the production date. I have a LS1Edit and I will tune it myself. I've had it for a wile, the program showed up 2 days after a piston gave up. I must of had a oddball mine never used oil but one time, that was the first 3000miles after I did the cam swap then it stopped and never used oil again.
Old Nov 6, 2004 | 12:56 PM
chevhot :
Just add cam, stock one blows. get a ls1edit or hptuners.
Or get raylar top end kit. for about ($5600+).
either will be good for more horsepower just that the bottom idea will require Allison trans upgrade, depending on how you drive.
andrewlong
Nov 9, 2016 09:38 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Superman09
Sep 25, 2015 05:55 AM
Brandonlflr12
Sep 9, 2015 03:54 PM
