wanna go lower
Old Aug 28, 2002 | 06:30 PM
redaddiction's Avatar
Default wanna go lower
Hey guys i guess i have a hotchiks 2/4 with swaybars and everything but i wanna go lower i use to have a 4/6 drop and was nice but wanted it to handle better so got this kit is there any way to go an inch or two lower front and back and keep the performance.
Thanks in advance
marc
Old Aug 28, 2002 | 08:10 PM
DuckOfDeath's Avatar
Default Re: wanna go lower
Did you have the swaybars on when you had the 4/6 drop?
Old Aug 28, 2002 | 09:39 PM
red53gmc's Avatar
Theoretically, you should be able to put 2" shackles on the back and be 2" lower. And in the front you can go 2" lower with either Belltech or DJM. (spindle or lower A arm)
OR
Get you some lower profile tires. That will give you the effect of a lower drop. You"ll still be only 2/4 but if you get tires that are 4" shorter than the stock 30" tires, that will lower you 2 more inches to the ground. (also make 2" more space between top of fender and top of tire)
I had my hotchkis 2/4 on my 01 and with 255/50-16 tires had the effect of 4/6 drop.
<small>[ August 28, 2002, 09:42 PM: Message edited by: red53gmc ]</small>
Old Aug 29, 2002 | 07:25 AM
Scream's Avatar
MOOBIES Moderator
The only problem that you might run into by going with another 2" in the rear is needing a notch.
I have a 4/6 DJM CalMax drop and I love it! I run 255/35-20's and have a little trouble with speedbumps and steep driveways, but the truck rides great!
<img src="http://acrophobia.net/images/scream/denial_sv.jpg" alt=" - " />
BCraven1018
Oct 1, 2015 08:22 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
X_Racing1
Sep 30, 2015 01:59 AM
Slammed silverado
Sep 28, 2015 06:14 PM
vmaxpro
Sep 28, 2015 11:10 AM
