Walbro Gss340 + 1 week = 10 psi at the rail??
Old Mar 4, 2005 | 02:23 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Question Walbro Gss340 + 1 week = 10 psi at the rail??
I am at a loss. Every e-pump I've ever dealt with either worked at full pressure or didn't work at all. My pump is putting out 10psi, unless the injectors are stuck open, but the truck does start and run for a little before starving out.
The regulator appears to be working -- pulling the vacuum reference doesn't change the pressure one iota.
Any ideas?
Old Mar 4, 2005 | 03:09 PM
hellbents10's Avatar
LS1Tech Sponsor
Fuel line inside of the tank?
Seen it happen before with intank setups.
Old Mar 4, 2005 | 03:10 PM
moregrip's Avatar
what a rush!
did you use the clear accordian tube?
Old Mar 5, 2005 | 09:24 AM
I AM A MOTHERF*CKER
We used high pressure rubber fuel line for all three lines (this is a dual set up).
What he did say was that the nipple at the pass through (on the ring) was too short to put a clamp on it, so he didn't clamp it thinking tension would keep the line on. When I told him how much pressure we run at idle and then explained about the second pump coming on, he thinks he might have to replace that pass through. Out of curiosity, what did you guys with dual pumps do about this?
05GMC4.8
Aug 7, 2015 09:55 PM
lxcoupe
Jul 21, 2015 02:12 AM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
