vortec 5.7
Old Dec 17, 2008 | 01:15 PM
04blackvho's Avatar
Default vortec 5.7
well guys i just brought a used 97 reg cab short bed 149,000 miles the truck has the tranny rebiult with a vette servo and shift kit,3.73 gears i want more power out of it what do you guys recomned
Old Dec 18, 2008 | 05:13 PM
hog's Avatar
hog
LT headers and exhaust
Camshaft
PCM tuning
Torque converter
the GM LT4 Hotcam has dynoed on a Vortec 383 at 330rwhp(around 400crank hp).
The stock poppet injection wont support much more due to the fact that they cant be swapped for higher flowing units.
Westers garage doies sell a flow matched spider however, they will support 440 crank hp.
peace
Hog
Old Dec 18, 2008 | 05:22 PM
brandont454's Avatar
gm spider injection upgrade
doesnt increase flow, but has better spray pattern and more reliable
Old Dec 18, 2008 | 06:27 PM
stock48's Avatar
9 Second Truck Club
A good tune will do wonders. Be sure the intake gaskets have ben replaced, they are prone to leaking coolant, and sometimes it leaks into the oil.
Old Dec 18, 2008 | 08:17 PM
2manycars's Avatar
Anybody have a link to the upgraded spider setup
Old Dec 18, 2008 | 08:29 PM
Truckshop's Avatar
my 96 had full bolt-ons. a crane 214-220 cam and 1.5 roller rockers. b&m 2400 holeshot convertor. truck ran 13.90 at 99 mph.
3.90 gears made a world of difference after the cam swap also. the only mods to the tune was added timing and zero tq management using jet dst.
Old Dec 18, 2008 | 08:32 PM
2manycars's Avatar
Was your 2400 converter pretty tight and did you have any surging issues? Also stock compression?
Old Dec 24, 2008 | 01:41 PM
gmc6's Avatar
The cam and a good tune will make a big improvement in that engine.
Old Dec 24, 2008 | 02:53 PM
blueflamed03's Avatar
just remeber with a cam over .440 lift, you'll need to have the heads re-done to accomodate the added lift.
Old Dec 24, 2008 | 03:36 PM
SILVERBIRCH's Avatar
Wheatley tune it, check out sponsors>>>>>>>>>>>>>>>>>
