Vinci cam
Old Jun 7, 2005 | 12:11 PM
white1's Avatar
Where does most of the lope come from? The LSA, or lift?
Old Jun 7, 2005 | 12:12 PM
white1's Avatar
Where does most of the lope come from? The LSA, or duration?
Old Jun 7, 2005 | 12:15 PM
00stepsyde's Avatar
Okie 5.3 what kind of power gains did you get with this cam.
Old Jun 7, 2005 | 12:34 PM
Kano's Avatar
Click here to see Video
heres one through dual 14" magnaflow ,x pipe and no cats dumped
my present tune is a bit overtuned for this cam
I think the idle air is way too high
Im gonna take it back closer to stock and see if I cant get it to sound a little better
Old Jun 7, 2005 | 03:23 PM
Okie5.3's Avatar
Yes and yes. The lope sound is caused by the exhaust valve opening earlier in the sequence of the valve timing events, either by increasing the duration or shorting the LSA for a given amount of duration. this cam on a wider LSA 114/116 would not have as much "lope" to it. also if you were to keep the same amount of LSA but reduce the duration of the exhaust lobe the "lope" would be less as well.
ahh, i'm not very good at quantifying anticipated results of bolt-ons or improvements. these trucks come from the factory with anywhere from 285-300hp at the flywheel. my results in sig are at the rear wheels. this is with the cam, tune, magnaflow 3"in/2.5" dual out, and e-fans. no headers or CAI. the tune was an inital tune and wasn't tested with cam. still need to tweak the tune a bit. it was pig rich in PE, like 10.5. believe there is another 25hp with just a good afr at 12.8-13.1. my pacesetters should be here tomorrow. i put the k&n 77 series on last night and i am ordering HPT in the next fews days. am planning another dyno session as soon as i get everthing installed and play with the tune a little.
damoncollins-can't wait to hear some sound bytes when it's in
Old Jun 7, 2005 | 03:24 PM
Okie5.3's Avatar
sounds awesome man. actually i think it sounds alot better than mine.
Old Jun 7, 2005 | 03:39 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Give Joe or Roger Vinci a call -- top notch guys
Old Jun 7, 2005 | 05:59 PM
Kano's Avatar
I dont know about that
coming through that flowmaster it sounds badass
another thing I noticed is that
the lope gets better with a TC
as far as gains
I have no before/after dyno numbers but
mine picked up 3 tenths in the 1/8th
Old Jun 7, 2005 | 06:47 PM
Gran Patron's Avatar
MAn I like loud and that sounds freakin Mean OKie! Sounds like my friends SS camaro I forget what cam he has tough
Old Jun 7, 2005 | 07:21 PM
BigBlackAv's Avatar
Berserker... where do you do your dyno... I want to put mine on after I get it back from Joe.
