Vacuum Leak??
Old Nov 4, 2009 | 01:21 AM
  #21
Fastcount03's Avatar
Lucas fuel treatment works well too! Wouldn't ether be good to use for a vacuum leak??
Old Mar 7, 2010 | 12:40 PM
  #22
Ender06's Avatar
Well I finally come to the conclusion it was my injectors. Shortened the spacers and now it idle's like a champ! Simple qick fix. I just hope i didn't shoten them too much. Can there be too much pressure down on the injectors?
Old Mar 7, 2010 | 01:11 PM
  #23
_zebra's Avatar
makes children cry
Originally Posted by BlackGMC
BTW did you put some vasoline on the injector orings before installing them?
do you think that not lubing one o-ring would cause my idle to drastically drop after hitting the clutch while driving? it only does this occasionally - typically when clutching in after a higher engine load (more after engine braking than acceleration). it'll drop to 300rpm or so & then back up to idle-ish.
this discussion reminded me that when i was installing the engine, i had to replace the #7 or #8 injector & i didn't know that the rings needed lubing.
Old Mar 7, 2010 | 01:19 PM
  #24
Ender06's Avatar
absolutely, mine would drop so hard at deceleration sometimes it would just die. really annoying. I didnt lube them, but tightened them down and no more idle probs at all. Try lubing them, its gotta help
Old Mar 7, 2010 | 02:31 PM
  #25
_zebra's Avatar
makes children cry
well... it's nice enough outside that i just might do that right now
03sierraslt
14
Oct 9, 2015 05:53 AM
GMCtrk
18
Oct 6, 2015 03:48 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
cousblake11
Sep 9, 2015 06:52 PM
custm2500
Sep 8, 2015 05:53 PM
