Vacuum.
Old Dec 24, 2009 | 03:45 AM
viciousknid's Avatar
Where's the Beef?
Default Vacuum.
Since I know a lot of you guys suck pretty hard I knew this was the best place to ask.
Other than the Intake gaskets, Where else can I check for a vacuum leak that would cause a rough idle?
Old Dec 24, 2009 | 03:46 AM
charcold-bowtie's Avatar
What kinda tune are you on?
Old Dec 24, 2009 | 03:52 AM
2005 Silverado's Avatar
SPAM HUNTER
Does yours have a fuel pressure regulator? OR is it return is it a return style fuel system?
Old Dec 24, 2009 | 03:53 AM
Where's the Beef?
My tune is in my sig. However the vehicle in question is 100% stock and has a mad leak somewhere to the point where it will barely stay running.
I'm still pretty sure it's the intake gaskets but I still have to buy some carb cleaner. It's for a coworker so I want to get all the options laid out before I do anything.
She said it does this every winter but is worse this year. Summer never has problems. That has me thinking gasket.
Dealership said the gaskets are good however I don't think they actually Sprayed them. They said it has a vacuum leak and just half assed it IMO.
Edit: BTW. unplugged MAF and ran fine the 1st time then started running ruff again. Maf on or off it's ruff
Old Dec 24, 2009 | 03:55 AM
SPAM HUNTER
Ask around and see if you can get ahold of a smoke machine, they work wonders.
Old Dec 24, 2009 | 03:57 AM
im boosted so im out.....
A stock vehicle, I really dont see gaskets just going out.
Old Dec 24, 2009 | 03:58 AM
Where's the Beef?
well I actually have 2 co-workers with seemingly the same issue. both over 130k miles.
Old Dec 24, 2009 | 03:59 AM
SPAM HUNTER
what kinda vehicle(s)
Old Dec 24, 2009 | 04:09 AM
Where's the Beef?
03 Sierra 5.3, 02 Tahoe 5.3
Old Dec 24, 2009 | 04:17 AM
SPAM HUNTER
Unplug the vacuum line from the fuel pressure regulator, and start the truck, if fuel leaks out bad deal, could cause a rough idle since fuel is getting sucked up. Also spraying the intake down can work. But smoke works better, i have also seen 1 or 2 randomly cracked intakes as well, but those where more the early 99-00 trucks.
