Are v6 and v8 motor mounts the same in the GMT-800 trucks?
Old Feb 21, 2013 | 08:41 PM
thunder550's Avatar
High on diesel fumes
Default Are v6 and v8 motor mounts the same in the GMT-800 trucks?
Frame pads and mounts...are they the same?
Old Feb 21, 2013 | 09:07 PM
_zebra's Avatar
makes children cry
no. and there's also a difference between 2wd & 4wd/AWD
normally shouldn't be too hard to find in a junk yard, but when i did my swap, i ended up having to order new ones from GM because every yard i called/went to somehow only had 2wd
Old Feb 21, 2013 | 10:33 PM
tfi racing's Avatar
Yep,you need the correct ones,not sure why they made these trucks with so many mount configurations,they all look the same until you have real close look.I got lucky,walked into a wrecking yard and the
2WD 5.3 frame mounts were just laying unbolted in the battery tray,2WD trucks are hard to find in this part of the world!
Old Feb 21, 2013 | 11:20 PM
_zebra's Avatar
makes children cry
it's because the v6 & v8 engines use 2 different style blocks requiring different mounting locations. then to make it more complicated, the 2wd & 4wd frames are slightly different up front to accommodate the different suspensions.
Old Feb 22, 2013 | 05:03 AM
LA FEA's Avatar
i pretty sure the actual motor mount itself is the same on 2wd v6 and v8 but the pedastel is diffrent
Old Feb 23, 2013 | 11:30 AM
tfi racing's Avatar
Nope,looks the same but flip them over and compare them,they will not interchange for a 2000,can't say for later years.
Old Feb 23, 2013 | 11:51 AM
_zebra's Avatar
makes children cry
i had to get both parts for each side on my swap
Old Feb 24, 2013 | 02:39 AM
LA FEA's Avatar
odd on my swap i used the 4.3 mounts sence they were new and just picked up new v8 pedastels i went from 4.3 in my 2000 to a 5.3 out of a 2001 1/2 ton 2wd
Old Feb 24, 2013 | 07:39 PM
_zebra's Avatar
makes children cry
hmm... maybe my 99 4WD was different? i grabbed the LM7 from an 01 Hoe
wrb002
Aug 31, 2015 12:00 PM
BennyB
Aug 1, 2015 08:48 AM
jmarkway
Jul 18, 2015 09:23 PM
black6spdz
Jul 16, 2015 01:32 AM
Nimoryan
Jul 5, 2015 03:50 PM
