Using perimeter bolt heads (and other compression q's)...
Okay I found a set of nonmilled (stock cc) perimeter bolt LS1 heads that I would like to use on my 5.3 motor.
The 5.3 is 9.5:1 comp stock w/ ~61cc heads. These heads are ~67cc I want to use. I read that I need a certain headgasket for the older heads for the coolant ports to line up too.
So what is it going to take to use the perimeter bolt heads on my 5.3 motor?
I'd like to keep my compression around 9.5:1-10:1 on the 5.3 motor also. Would I need a thinnner headgasket and to mill the heads to achieve my desired compression ratio? Can the LS1 heads be milled .030-.050 safely?
I am lost when it comes to adapting these heads...
hit man did you find the info i was telling you about?? i forgot and have not looked. o and like i said befor you might need the coils. cause i remember on my friends car i told you about having the problems on we had to use the older coils. one more thing you might want to check on.
slowlsx
Aug 10, 2015 05:33 PM
signguy62
Jul 27, 2015 03:42 PM
