Update on my ATI S/C
Old Jun 20, 2005 | 11:14 PM
Default Update on my ATI S/C
Well today I got my VCM flash update for hp tuners, so I did some tunneling with the help of a friend. I think that I got my KR taking are of. All I really needed to do was richening up the tune a little bit, and get more fuel. Also I put in two bottles of Lucas octane booster. Then latter tonight I put the new pulley on along with a shorter belt. I started it up and everything looked ok, but I will have to give it the test tomorrow along with some more tuning.
Old Jun 20, 2005 | 11:16 PM
Black Blown 02's Avatar
What pulley did you go with?
Old Jun 20, 2005 | 11:23 PM
Old Jun 20, 2005 | 11:33 PM
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
What will that put the boost at?
Old Jun 20, 2005 | 11:38 PM
i am shooting for 10psi but i don't know what i will be getting till tomorrow. i just ran out of light tonight and will have to do some more tuning before i really open her up.
Old Jun 20, 2005 | 11:41 PM
BeefTip's Avatar
So are you going to have enough fuel for the extra boost. Im not sure what you were running before so it might not be a problem. Im glad you got that tuning crap worked out, you almost gave up on it.
Old Jun 21, 2005 | 07:16 AM
i should be able to throw enough fuel at it. i have 42lb injectors and a inline fuel pump.
Old Jun 21, 2005 | 07:34 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Glad to hear you finally got things sorted out. Bugs that you cant figure out will drive you nuts.
Old Jun 21, 2005 | 09:14 AM
ok on my way into work today i did two short runs. on the second run i did a dead stop run and at 80mph it was like i lost power and i let out of it real quick. then i checked my DTC's and the code that was up was P0174 - Fuel Trim System Lean Bank two (OLD) (Current) (Immature)
Old Jun 21, 2005 | 11:26 AM
Where do your long term fuel trims sit at? If you don't know, you need to log them while you do some normal driving. I think they'll only adjust 15%, if any more adjustment is needed, it will throw that code and you need to tweak your injector flow rate.
