UPD CARB Approved?
Old Apr 6, 2004 | 12:22 PM
leochevy2001's Avatar
Default UPD CARB Approved?
I don't know if this has been asked before but is the UPD CARB approved? If not, will I still be able to pass state inspection with it on my truck?
Old Apr 6, 2004 | 04:04 PM
Hit Man X's Avatar
Should be able to. I have a K&N cone setup on my truck and e-fans that aren't CARB...you should see under the hood of my F150, nothing under there is CARB and it passes without greasing the inspector. If you're worried, just find a dumpy inspection place...even so most you could probably convince that the UPD is OE...
Old Apr 6, 2004 | 05:23 PM
How does CARB apply to Texas? I thought CARB was a Cali only thing? It sure sucks to live here in Kalifornia.
E-fans, are not a CARB item here in Cali as they do not affect emissions in anyway as they are not tied to the volumetric efficiency of the engine.
Old Apr 6, 2004 | 05:28 PM
LOW2000's Avatar
CARB = California Air Resources Board
Some other states use our guidelines though since they are the most stringent in the country, if you can get your part carb approved, then it will be accepted by any state.
Old Apr 6, 2004 | 06:11 PM
one03sierra's Avatar
Formerly one92rs
Talking
well i just got mine inspected with it on there.
Old Apr 6, 2004 | 06:34 PM
CHAGO's Avatar
I think they said TX is 4th strictest regarding inspection crap, but an intake should not cause you to fail
Old Apr 7, 2004 | 06:14 AM
Cool Thanks guys for the info.
LSXstef
Jul 19, 2016 02:59 PM
Skip Fix
22
Jul 9, 2016 07:08 PM
dirt track racer 81
Sep 21, 2015 06:44 PM
reddfox
Sep 15, 2015 07:22 PM
