upcoming lq9 swap
Old Sep 22, 2008 | 05:00 PM
  #31
Wheatley's Avatar
Truck Sponsor
Thanks again Mike,your PCM is shipping out with all the rest in the morning.It is already flashed and boxed up
You will have a tracking number this evening by 6PM central time
Thanks again
Wheatley
Old Sep 22, 2008 | 05:59 PM
  #32
GMCtrk's Avatar
Originally Posted by 69Boss302
I just spoke with Charlie Wheatley and ordered the tune since I've decided to just roll with the engine I've got and hope for the best. I got a pretty good fuzzy after talking to the construction company that it was well maintained.
Zippy -
I drive an average of 2,000 - 2,500 miles per week with an average of 5 or 6 fillups. I've noticed an average of $.50 difference from 87 to 93 in the area I cover. That's how I get close to $100 difference a week. Give or take $5 or $10.
Well, you know the saying, good things happen to good people. I think the engine should be just fine. My 75k LQ9 looked very rough around the edges. The escalade it came out of was also in a front end collision. But alas, I've put 3k miles on it since the swap and it runs like a brute, great oil pressure, proper temp, and it fired up on the first turn.
Old Sep 23, 2008 | 05:12 PM
  #33
SnakeOiler's Avatar
Zippy -
$100 would be your worst case scenario based on what your are saying. I figure $40 difference would be your best case scenario.
And curiousity is killing me - what do you do that causes you to drive that much?!
Good luck with the 6.0 - one day I might do that myself.
Old Sep 24, 2008 | 12:26 AM
  #34
05RST2NV's Avatar
Originally Posted by GMCtrk
see, I told you. There's no way in hell you're getting a 9000 mile LQ9 for $1000. Good 05+ LQ9's go for 2000 plus all day. Trust me when I say that using an 05+ LQ4 is outstanding. The single difference is the lower compression which is a 10HP difference. Not even noticeable. Plus, they are about $500 cheaper.
Im on the hunt for a 05+ LQ9 as well.. Anyone know off hand how much a new LQ9 long block is from GM?
Old Sep 24, 2008 | 12:36 AM
  #35
GMCtrk's Avatar
I believe I read that GM discontinued LQ9 production.
Old Sep 24, 2008 | 12:54 AM
  #36
05RST2NV's Avatar
Well that sucks.. Whas the options now? The 6.2 only?
Old Sep 24, 2008 | 01:12 AM
  #37
GMCtrk's Avatar
I think you can get a LQ4 crate engine from Scoggin Dickey for $3700
Old Sep 24, 2008 | 06:50 AM
  #38
zippy's Avatar
Call your dealer with either of these two part numbers.
12491860
89018179
Should be between 3300 and 4200.
Old Sep 24, 2008 | 11:31 AM
  #39
05RST2NV's Avatar
12491860
89018179
Dang that much? I can get a low milage, intake to oil pan engine off ebay cheaper than that. Thanks for the info.
Old Sep 24, 2008 | 12:00 PM
  #40
GMCtrk's Avatar
What do you expect? You're comparing a new, warrantied engine to a used non-warrantied engine. Go with the used one hands down. I would highly recommend Schram Autoparts from what I've seen. I learned my lesson. When buying a used engine don't skimp out. One from Schram may cost $2500, but it will be packaged perfectly, have all parts, and it will have been removed from the vehicle professionally. Anything less is just a crapshoot.
