Ultimate 5.3 setup
Old Sep 7, 2006 | 02:30 PM
99/5.3w/hips's Avatar
Default Ultimate 5.3 setup
If you had a rcsb 5.3 and money was not an object but you wanted to build a 5.3 instead of dropping in a 6.0, what would you do?
forged internals?
huge cam?
aluminum heads?
There are a ton of options out there.
What would your ultimate 5.3 be? The purpose of this is to see what types of ideas people have as far as getting the most power out of a 5.3 instead of just dropping in a 6.0. I think answers not involving FI would be better but hey its your ideas right? What would you do to make the most powerful NA or FI 5.3?
Old Sep 7, 2006 | 04:58 PM
StrokerAce03's Avatar
I'd bore it out to use ls1 pistons, a good cam, high flow heads, and high compression. That's after all bolt-ons, exhaust, etc.
Old Sep 7, 2006 | 05:02 PM
speedy02's Avatar
Turbo pawah with forged internals!!
Old Sep 7, 2006 | 05:03 PM
forged internals (Eagle setup most likely) with a set of AFR 225's, Big cam, something like a 232/240 or so with close to .600" lift.
Old Sep 7, 2006 | 05:10 PM
silver-mod-o's Avatar
Hunt&Fisherator
use the block and make a 383 out of it with some ported AFR 205's, Vic Vr intake 90mm TB and about a 234 cam, 4200 stall and some 4.56's... dont forget the 300 DP shot of N2O
Old Sep 7, 2006 | 05:11 PM
FarmerBeau's Avatar
Sexy Party Mod
FYI- your stock heads are aluminum.
Old Sep 7, 2006 | 05:12 PM
v8
17,16,15,14,13,12,11 Drvr
not sure still trying to figure out what I need to do to my 5.3 to make it make power.
Old Sep 7, 2006 | 05:22 PM
I thought they were cast iron
Old Sep 7, 2006 | 05:36 PM
TXsilverado's Avatar
Old Sep 7, 2006 | 06:31 PM
negativeswitches's Avatar
vortec heads are alum.
truck blocks are cast iron
