UDP...stupid question?
Old Oct 24, 2010 | 04:41 PM
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
Default UDP...stupid question?
I'm getting a Powerbond UDP in a few weeks & I'm trying to get all my ducks in a row before installing it.
Here's my question: Should I get the tool or should I heat it?
I saw a how to that said to heat the UDP in the stove @ 400* for about 15 mins. It would seem like that would melt the coating off of it. If not melt it off, it would seem that it would at least soften leaving marks from where I was holding it. That & having to wear oven mitts while transporting it from oven to the truck & then slipping it onto the crank.
Old Oct 24, 2010 | 05:29 PM
grey matter 04's Avatar
13 Second Truck Club
do it the correct way rent the tool
Theres a rubber part on the pulley that will melt...i know a guy who is **** and powdercoated his pulley and the heat from the baking process ruined his ASP pulley
Old Oct 24, 2010 | 05:30 PM
dirt track racer 81's Avatar
Let me know if you need a tool to press it back on with.
Old Oct 24, 2010 | 05:38 PM
badz24s's Avatar
That's what I thought. Thanks
Will be needing one in about 2 weeks
Old Oct 24, 2010 | 05:57 PM
Originally Posted by neilownz
Don't you just put it on flush with the old bolt, put the new bolt in, torque it etc etc...
That's a good way to tear up the threads in the crank. Been there done that.
Old Oct 24, 2010 | 06:50 PM
brent5631's Avatar
Put it in the oven at 250-300. Use a longer bolt to get it on then use the new bolt and torque it down.
Old Oct 24, 2010 | 07:33 PM
dlt76028's Avatar
well you need a puller regardless to get the old one off. When I put mine on, I put it in the oven for about 20-25 mins and it slid in enough to get the bolt to pull it in.
Old Oct 24, 2010 | 08:24 PM
badz24s's Avatar
Got a 2 jaw 7 ton puller...should be enough
Old Oct 24, 2010 | 08:46 PM
DO NOT HEAT PULLEY!!!
Use the tool do it the right way..why chance messing the threads up in the crank snout?
Talk about F your day up when the threads gaul up or rip out of the crank!
Your truck your decision
Old Oct 24, 2010 | 09:26 PM
badz24s's Avatar
thanks cody
