true duals
Old Oct 28, 2009 | 01:51 AM
armstrong87's Avatar
Default true duals
first off im a newbie but im not really familiar with searching here but i have a 04 silverado w/ the 4.8, cold air intake, no cats, and i was wondering if i was to go true duals will it hurt my performance, also wat sizze pieing do i need to run
Old Oct 28, 2009 | 10:40 AM
PathfinderJr's Avatar
if you want to go duals, don't go any larger than 2.25" piping. The cross sectional area of that is slightly larger than a single 3" which is what a lot of folks run. The smaller pipe will help keep exhaust gas velocities up in the lower rpm, which in turn helps cylinder filling, which in turn helps low-end performance.
Old Oct 28, 2009 | 07:01 PM
06WT's Avatar
i think you would see better #s with a y set up with a 4.8, but as pathfinder said if you decide to go with duals stay close to 2'' tubing
Old Oct 28, 2009 | 08:11 PM
vista4.8's Avatar
no need for duals on a 4.8, low end already sucks as it is. the stock 2.75 is more than enough to handle anything you throw at the motor.
Texas5.3_1251
Mar 5, 2016 08:10 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
sTNT971
Sep 26, 2015 04:22 PM
Duramaxin14
Sep 12, 2015 08:04 AM
