true duals
Old Dec 21, 2007 | 07:45 AM
Phantom's Avatar
11 Second Club
if you're gonna run true duals 2.5"
Old Dec 21, 2007 | 07:50 AM
KevinF56's Avatar
damn blackgmc, you do nice work.
Old Dec 21, 2007 | 08:44 AM
BlackGMC's Avatar
Resident Retard
Thanks!
That ture dual setup was LOUD.... Eric and I are going to run tail pipes next weekend all the way to the bumper in each corner.. it should be fun and hopefully kill some of the loudness
Old Dec 21, 2007 | 08:56 AM
kw05silverado's Avatar
pm me x pipe 45 bucks new 2.5"
Old Dec 22, 2007 | 01:46 PM
joshua022's Avatar
I think I have decided on what I want to do.
I'm going to put a lot of flanges in so it can be easily re-moved. like at the longtubes and then right before the x-pipe and then right after the mufflers.
I'm going to use my ORY pipe and cut it at the "Y" section and then use 2 reducers to reduce it to 2.5 for each pipe and then I'm going to put in a x-pipe and 2 resonators on each pipe and then into 2 speedrex mufflers 2.5in/out. then I'm going to use the tailpipes I already have on my truck so that they turn down right at the edge of the bumper like the old muscle cars did.
That sound like a good plan?
Who makes a good but relatively small resonator?? flowmaster, or the dynomax bullets??
Thanks and Merry christmas
Old Dec 22, 2007 | 02:03 PM
BlackGMC's Avatar
Resident Retard
Sounds like a good plan, that is similar to what we did with Eric's exhaust. Next weekend we are going to run pipes all the way out to the bumper.
I put flanges all over mine and Erics so it can come out easier too. The easiest way I found to flange exhaust is assemble the two flanges with 1 thick washer inbetween them. Then slide the assembly onto the pipe so you can position it where you want it. Tack everything up all the pipes, tacking the flanges last, then remove the bolts and washer. Then take a saw and cut inbetween the flanges. The take everything down and weld it all up. Word of advice about flanges is to weld them inside and out. The grind down in inside part.
Old Dec 23, 2007 | 01:31 PM
joshua022's Avatar
BLACKGMC
Where could I find some flanges?? or where did you get yours??
I'm gonna need:
two 3" flanges for both headers
two 2.5" 's for in front of the xpipe
and two 2.5"''s for behind the muffler
Old Dec 28, 2007 | 06:50 PM
MorepowerTY's Avatar
Here ya go. Just do a seach of your size.
http://store.summitracing.com/egnsea...9+115&x=30&y=8
Old Jan 9, 2008 | 09:43 AM
low2001gmc's Avatar
dozerdan, nice curves on that exhaust system you made. thanx for the tips to all...
rob
Texas5.3_1251
Mar 5, 2016 08:10 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
sTNT971
Sep 26, 2015 04:22 PM
Duramaxin14
Sep 12, 2015 08:04 AM
