Truck takes long time to start. Could I advance cam timing to help it?
Old Nov 26, 2013 | 11:38 PM
2008SilveradoGhost95's Avatar
Registered User
Default Truck takes long time to start. Could I advance cam timing to help it?
Every time I start my truck it takes a good 3 or 4 seconds for it to finally turn over. I put a cam in it and I lined up the marks on the timing gears, should I advance it one tooth or will that even make a difference? And my cam pos sensor is making my check engine light come on, does it have a better chance of just getting a tune instead of all that?
Old Nov 27, 2013 | 12:30 AM
niebs's Avatar
the cam specs should have said to run it advance or not. the computer may alos need time to learn that you changed the cam. try re-sitting the ecm.
Old Nov 27, 2013 | 10:04 AM
gagliano7's Avatar
Get a tune.
Old Nov 27, 2013 | 10:19 AM
03sierraslt's Avatar
^ get a tune.
Old Nov 27, 2013 | 10:27 AM
Vortec350ss's Avatar
Yup a tune is the way to go here... a cam swap isn't even worth it without one to be honest.
Old Nov 27, 2013 | 11:01 AM
Atomic's Avatar
I have a gauge for that
Its a fueling issue. Valve events change the injection period greatly.
Old Nov 27, 2013 | 08:25 PM
LsF-150's Avatar
Fix the cam position code and you'll fix the extended crank. What did you change inside the timing cover? When the cam sensor signal is lost you lose sequential injection and are left with batch injection, meaning instead of firing the injectors in the firing order it just fires one bank and then the other, this causes the extended crank because your just relying on a cylinder to finally come around to tdc compression stroke at the right time the injector has been "batch" fired.
SLOPONY
20
Oct 18, 2016 06:05 AM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
Aboss
Jul 9, 2015 10:28 AM
