Truck runs like crap when i get to 1/4 tank....
are you guys letting your gas level go below 1/4 tank before filling up? i try to keep mine above 1/4 so the pump doesn't burn up...45k just seems a little early for a fuel pump..atleast IMO
Believe it or not, the gas in the tank keeps the pump cool...when you continuously run the tank low, the pump begins to overheat and causes premature failure. Your truck is a 04..iirc, the fuel filter is in the tank. if so, i'd definitely change it when you're replacing the pump. You'd be suprised how much harder the pump has to work due to the filter being clogged.
