Truck Nationals at Epping May 22nd *Roll Call*
#41
Sounds like a cool exhaust. I dont have any cats or even a Y-pipe though. It would be a good deal for 04BlackSilverado to buy though...hint,hint.....
I bet with the e-fans, tune and that exhaust we could get you into the mid 14's......
#43
Bring them, if you will let me try them and I like them, I will bring cash.
I'm going to swap the radiator tomorow and install the fans, the harness just got here, looks sweet!!! I will have to manually operate the fans untill sunday, not a big deal as long as they will be turned on be then.
Any tips for the swap?
im gonna get some coolant and trans fluis cause i will spill some i think. But is there any tricks that will help me out?
#46
Originally Posted by TnTrk53
Sounds like a good time in the making. Is this really an all truck show?
I will be spraying the **** out of my truck too. So i am looking for a new best, even if i am stuck on street tires.
#50
Still want to come up if it rains?
I just finished putting in the 34" radiator but left the clutch fan on because i wasn't sure how to wire up the manual switch?
I didnt see a logical place for the ground wire, or if the pcm matterd with the manual switch or not.
Well whatever, It still cools it enough without the fan shroud on, and I pre wired the harness so the rest or the swap should be easy.
Everyone should still show up, because we can still have a good time even if the track isnt open
Well whatever, It still cools it enough without the fan shroud on, and I pre wired the harness so the rest or the swap should be easy.Everyone should still show up, because we can still have a good time even if the track isnt open
