Truck members using E-Fans?
Old Sep 2, 2004 | 07:06 PM
diamondd2's Avatar
I used LT1 fans. All it took to install was 3 brackets made out of 1/8" thick x 3/4" wide flat steel and one- 1/4" nut and bolt. Got a wiring harness from Allen, and I have it run off the PCM. The install took about 2 hrs. It looks good and works like it was factory.
Cost:
LT1 fans off ebay = $125
Harness = $90
Steel = $4
5/16 rubber hose = $5
I posted some pics of my lt1 fan and harness install in this thread https://ls1tech.com/forums/showthread.php?t=203851
Old Sep 2, 2004 | 07:09 PM
XLR8NSS's Avatar
Adkoonerstrator
I've got the flex-a-lite 282s on my 6.0L radiator. The VSC has performed flawlessly on mine for a long time now.
The FALs are nice fans.
Old Sep 2, 2004 | 11:58 PM
blk03's Avatar
damn, the harness from Nelson is $90? I thought it was a little cheaper.
Old Sep 3, 2004 | 01:21 AM
kwkshift's Avatar
check sig.
Old Sep 3, 2004 | 09:16 AM
diamondd2's Avatar
There are 2 harnesses available. A 2-relay harness for about $49 or $59 and a 3-relay harness for $89.
I got the 3 relay. Worth the money? YES.
=Dave
Old Sep 3, 2004 | 09:46 AM
FILE's Avatar
=Dave
I have that same 3 relay set up. I am curious how Allen's set up looks. Can you post pics of it or email them to me at shark_g@yahoo.com
Old Sep 3, 2004 | 01:58 PM
diamondd2's Avatar
Look at post #11 in this thread. There is a link to a thread were I posted pics of the harness.
=Dave
Old Sep 3, 2004 | 02:33 PM
therock's Avatar
What are the differences between the 2 & 3 relay harness?
Old Sep 3, 2004 | 08:22 PM
2000silv5.3's Avatar
stay away from the hayden dual fan switch its a pos. the contacts on the relay keep fouling and it melted the fuse and holder.
Old Sep 3, 2004 | 11:49 PM
Flyer's Avatar
THe Hayden thing you're talking about is actually a nice piece, but it is WAAYYYY to skimp[y for these hefty fans. I'm using it on my fan system to switch for the low temp and A/C relay, either or for the low speed and the PCM for high speed.
Used as the only method of controller, yes, it would most certainly suck a big one!
