Truck idling high too high and trans not shifting right
Old 11-25-2009, 12:42 PM
Registered User
Black99Silverado's Avatar
Default Truck idling high too high and trans not shifting right
I have a 99 silverado 5.3 with the 4l60e trans. Stock internals just magnaflow exaust cai no cats. It will idle and shift fine but after a while the idle goes up to 700rpms in gear and 1000 at park. The trans wont shift right, it hangs gears and wont shift till i let off. Does the tps control shifting in these trucks? Could it be a IAC problem or a transmission problem. Does it more when engine is in closed loop at normal operating temps. No codes.Anyone got an idea before i start throwing money at it.
Old 11-25-2009, 01:21 PM
waterdog's Avatar
Mine has done the exact same thing. Doesn't always do it but when it does its after its warmed up. I have a built transmission and replaced the 5.3 with a 6.0L. No codes as well
Old 11-25-2009, 02:01 PM
waterdog's Avatar
I heard a contaminated MAF can cause this, oil from k&n filter. I would try to clean it with seafoam before you replace any parts. I would try it with mine and let you know but im waiting for my pcm to get retuned.
Old 11-25-2009, 06:05 PM
1dirtybird's Avatar
Get some contact cleaner to clean the maf, pull the t/b off and give it a good cleaning with some carb cleaner. You can also pull out the iac and clean the whole passage with a tooth brush. Good time to do the coolent hose bipass too.
Old 11-25-2009, 06:06 PM
Wearin' da big hat
00ChevyScott's Avatar
Pull the battery cable for 30 minutes and see if that helps.
Old 11-25-2009, 06:18 PM
Registered User
Thanks for the replies. I will try that and see if that helps. Nobody thinks its a sensor problem right? Cause it would throw a code?
Old 11-25-2009, 06:40 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
It sounds like it may be a vacuum leak to me. That explains the high idle anyways. Not sure how that could affect the transmission shift, unless the MAP signal has something to do with it.
Old 11-25-2009, 06:41 PM
waterdog's Avatar
I would guess the throttle position sensor could cause it but I would try cleaning the maf first. I goggled it earlier and that's what worked for most, the oil from aftermarket filters a screw with it.
Old 11-25-2009, 06:44 PM
Yes, TPS can do this also.
Old 11-26-2009, 07:11 AM
PT's Slowest Truck
budhayes3's Avatar
I agree, as mentioned I'd start with cleaning the MAF and Throttle Body, cheapest, easiest place to start, and may very well cure your problem.
Quick Reply: Truck idling high too high and trans not shifting right
