truck fuel system
Old Apr 4, 2004 | 08:46 PM
slow's Avatar
Default truck fuel system
how do the truck fuel system work?
is there a return line off the rails? if so, which years/motors have that.
im looking for a OEM return style rail for my TA, but don't like the price of the 97 vette rails, i've heard rumors of the truck rails being different.
also, how does the fuel pressure work? static, at 58psi, or vacuum referenced?
where is the regulator located?
thanks guys
Ryan
Old Apr 4, 2004 | 09:55 PM
XLR8NSS's Avatar
Adkoonerstrator
The truck fuel system is basically the same as the 97 vette.
- Fuel rail mounted manifold vacuum referenced regulator(driver side)
- Fuel return off the driver side rail.
- 58psi at 0 manifold vacuum.
The difference is that the trucks use smaller injectors with totally different electrical connectors. Because of these smaller injectors the mounting ears on the rails might not line up right with the LS1 manifold. The crossover on the truck rails is also much higher than the Fbody crossover because it has to clear the truck manifold which is very tall. This might look kinda goofy on a Fbody.
IMO, you'd be much better off just breaking down and getting the vette setup. Less hassle to make work and looks much better.
Old Apr 4, 2004 | 10:17 PM
Banned
if you don't like the vette setup, contact speed inc. they have a nice setup that's pretty reasonably priced.
jdb11386
Dec 3, 2015 09:34 PM
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
Deceptarado
Jul 8, 2015 05:24 PM
