truck dies under load or wot
Old May 20, 2005 | 04:09 PM
L P C's Avatar
Default truck dies under load or wot
i need a little help here guys. my other truck is a 96 5.0 vortec and all of a sudden it started dieing when i accelerated. it either does it if it sits and idles for a few mins or if i moderately accelerate. it does fine first thing in the morning for about 2 minutes and then blahhh. it acts like it is bogging down or sufficating. it also lets off little backfires when it does it, i changed the fuel pump thinking it was it and there is no differance
Old May 20, 2005 | 04:39 PM
SS Crew's Avatar
Check your plug wires. I had a an '85 Monte Carlo SS that used to burn up the #7 plug wire every 30k miles and cause the problem you are describing.
It may also be a vacuum leak. Check your hoses.
Old May 20, 2005 | 04:46 PM
litreddevil's Avatar
Banned
check fuel pressure change fuel filter,then take out the 2 front O2 sensor and run it and see if it does it still,if so check cap & rotor.
Old May 20, 2005 | 09:07 PM
officialfoxracer2006's Avatar
fuel filter would be my guess...
Tig
Sep 30, 2015 07:39 PM
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
fcompean
Jul 15, 2015 09:55 PM
lxcoupe
Jul 14, 2015 10:14 PM
