Trick Flow camshafts?
Old Nov 25, 2007 | 11:32 AM
hirdlej's Avatar
Default Trick Flow camshafts?
Has anyone here used trickflow camshafts yet? These are a bargain compared to other existing cams out there at only $269.99 a piece. Quality I'm told I shouldn't worry about since they are Lunati blanks which are ground by Lunati as well. I am building a 6.0 that will be completely stock for a rcsb 2wd truck. I am wanting to do cam and headers only. The 2 trickflow cams I was looking at are:
Product Line: Trick Flow Track Max Camshafts for GM LSX
Part Type: Camshafts
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,000-6,000
Intake Duration at 050 inch Lift: 216
Exhaust Duration at 050 inch Lift: 220
Duration at 050 inch Lift: 216 int./220 exh.
Advertised Intake Duration: 330
Advertised Exhaust Duration: 330
Advertised Duration: 330 int./330 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.560 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.560 in.
Valve Lift with Factory Rocker Arm Ratio: 0.560 int./0.560 exh. lift
Lobe Separation (degrees): 114
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: Yes
Quantity: Sold individually.
Notes: Computer modifications recommended for best performance.
Camshaft, Track Max, Hydraulic Roller Tappet,Advertised Duration 330/330,Lift .560/.560,Chevy,Small Block,Each
Or the
Basic Operating RPM Range: 2,500-6,300
Intake Duration at 050 inch Lift: 220
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 220 int./224 exh.
Advertised Intake Duration: 338
Advertised Exhaust Duration: 338
Advertised Duration: 338 int./338 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.575 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.575 in.
Valve Lift with Factory Rocker Arm Ratio: 0.575 int./0.575 exh. lift
Lobe Separation (degrees): 112
Has anyone used either of these camshafts, if so did you like them? Otherwise how do you think these would perform? I can't see where spending another $130 on a comp or thunder racing cam would be beneficial. If anyone has used either of these, do you have soundclips?
Thanks
Old Nov 25, 2007 | 12:40 PM
dkota1968's Avatar
I was also looking at these cams but one thing i would look at is they recommend 10.5-1 compression. You would definetly want a stall with the bigger of the two seeing the rpm range, lunati does have a good rep so for the money it should be worth it.
Old Nov 25, 2007 | 01:10 PM
Rhino79's Avatar
9 Second Club
That is a lot of advertised duration!
Old Nov 25, 2007 | 01:13 PM
07 z71 silverado's Avatar
11 Second Club
thats exactly what i was thinking
Old Nov 25, 2007 | 01:48 PM
hirdlej's Avatar
I was looking more at the @ .050 numbers more than anything. That's gotta be a mistake, not even the highest comp solid roller cams have an advertised duration that high. Although I did copy and paste the information directly from trick flow's website. A phone call will be in order to TEA in the morning as I will more than likely be buying from them. Here is a super write-up I found over on tech about the trickflow cams. https://ls1tech.com/forums/showthrea...t=#post5446951 Those power curves look absolutely astonishing. On stock heads, a guy should be able to mimick those power curves, they just won't be as "intense".
Old Nov 25, 2007 | 02:49 PM
dkota1968's Avatar
those curves do look good, 220 cam looks like it would work out nicely, maybe even advance it a few degrees. That kinda power seems like its high for the mods but curves nicely.
Old Nov 25, 2007 | 03:00 PM
dlt76028's Avatar
I was also looking at this one for my 4.8l, they look pretty good to me.
http://store.summitracing.com/partde...1&autoview=sku
thompson
Dec 27, 2017 06:48 AM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
Silver8ado
Sep 30, 2015 11:42 AM
Rockrz
Sep 29, 2015 09:07 AM
