Transmission woes
Old May 23, 2003 | 06:53 AM
Scream's Avatar
MOOBIES Moderator
Default Transmission woes
I'm having some weird tranny issues! At times, the truck doesn't want to downshift. If I manually select a lower gear, it's fine.
I was having a whole lot of SES codes when I did the cam, and I was told by some local LS1 buddies that the SES light can foul up the converter's functions, so I thought that might be the culprit. But, now that the idle is better, I'm only getting the Misfires code every now and then, and it usually goes out very shortly. Last night it did it again, and there was no SES light.
Anyone have any ideas? What steps can I take to correct this problem? Rebuild? 4L65E? Lightning? (j/k)
Old May 25, 2003 | 08:36 PM
Default Re: Transmission woes
Scream, no new 14 sec time slips yet? How did you finaly fix the idle issue? I may be wrong but I think down shifts are controlled by throttle position, and speed. Have you tried setting your shift pionts up higher? That may let it down shift at higher RPMs.
Old May 28, 2003 | 01:32 PM
Scream's Avatar
MOOBIES Moderator
I haven't changed any settings on the HPPIII, so I don't think that has anything to do with it. The truck was shifting fine with the HPPIII .
Does anyone have any thoughts?
Old May 28, 2003 | 03:36 PM
XLR8NSS's Avatar
Adkoonerstrator
Do you know what codes were/are being thrown?
I've looked through my LS1Edit file and just about all the trans functions are controlled by throttle position in some way. I've heard misfire codes will cause converter problems also. If you run a search in the Drivetrain section maybe you could find some info on that.
I'd say it probably has something to do with the codes but, it could just be something mechanically wrong.
My $.00
Don't be joking about getting a Lightning now.
Old May 29, 2003 | 07:06 AM
Scream's Avatar
MOOBIES Moderator
Well, it's doing it now and there aren't currently any codes showing--the light is off and there aren't any codes stored in the PCM.
I'll do some more searching...thanks!
calsdad
Jun 14, 2023 11:07 PM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
nabozny21
Oct 17, 2015 07:47 PM
jscherbs
Sep 30, 2015 07:54 AM
