transmission almost always in "cold" mode
Old Dec 1, 2003 | 09:28 AM
graygmc's Avatar
Default transmission almost always in "cold" mode
i talked to runwalk about it and he is going to have my ECT checked out. i was just wondering if anybody else has had this happen to you. i hope it is not from the servo or even the cooler i put on. it shouldnt be though.
Old Dec 1, 2003 | 02:01 PM
FLASH's Avatar
what exactly is the transmission doing
Old Dec 1, 2003 | 02:04 PM
Hit Man X's Avatar
Do you think it is due to the HPP3 on your PCM? If I remember correctly yours had some error and is permantly attached...
Old Dec 1, 2003 | 04:36 PM
Banned
what is "cold" mode exactly.....mine does some weird stuff also, but i am starting to attribute it to a trashed converter
Old Dec 1, 2003 | 07:24 PM
YellowChevy4.8's Avatar
speaking of....just recently (when it finally got cold here) my TC does not lock up until it is up to operating temperatures ~160-180 degrees. When it warms up, then it works fine. Is this the same thing you are talking about?
Old Dec 1, 2003 | 10:02 PM
Does anybody know which temperature is used to enable the trans hot/cold mode? Is it coolant temp or trans temp?
Old Dec 1, 2003 | 11:34 PM
VicRed's Avatar
I believe its the Coolant Temp, but im not 100% sure
Old Dec 1, 2003 | 11:39 PM
graygmc's Avatar
basically it is just shifting gears later than normal at part throttle. wont shift into 3rd until about 30 and 4th about 40mph. this doesnt happen all the time though. like today it was like 65* and still doing it while i was driving for over 45mins. so i know my temp was up. plus my fans were completly turned off.
Old Dec 2, 2003 | 07:56 PM
Mine does it to when temps below 50 on mirror thermo.shifts perfect once I reach 160.
Old Dec 2, 2003 | 11:21 PM
Flyer's Avatar
I remember reading in the Owner's Manual that this was a feature to help heat the engine up quicker when it was cold outside so you would gain use of the heater sooner. It should begin shifting normal after everything warms up though.
Can you ATAP it and see what your tranny temps are?
