Transgo, Vette Servo, Cooler Installed
Originally Posted by SuperSporttruck
yeary,
I did the exact same install on my truck and it is not hard it just takes a little time and its messy, but after your done it is well worth it.
I'm gettingmy Transgo and vette servo in next week but I wont be able to get the supercooler in for a couple more weeks is this acceptable? I assume I have a stock cooler in already. I cant get out and check right now! What do you guys think aboout not getting the cooler done for a couple of weeks after the other install?
If you're upgrading the servos, use no washers. Be conservative with opening up the feed holes. Open the 3rd feed hole up as much as you can without getting into the HD/Race settings.
The cooler was one of the first things I did to mine, especially since I didn't have one already.
If it were me ... I wouldn't use any washers in mine. I would rather open the feed holes up a little more if the shift wasn't firm enough for me. The washer in there makes it pretty brutal, especially if you have good friction materials in there.
