transgo and servos
Old Apr 14, 2004 | 07:25 AM
Lightbulb transgo and servos
got the new billet's in (now have no fourth gear ???? and yes i did put both billets in) and still no hard shift in 1st.... torque managment maybe ?????
Old Apr 14, 2004 | 07:31 AM
Flyer's Avatar
The seal on the billet OD servo is more than likely cut. Take the servo cover off and check that seal.
If that's the case, when you get a new one, put the OD plate in the cover, then stick the whole thing on there making sure not to **** it to the side in the cover or pull it out of the cover. Use a small screwdriver to help get the seal down so it will fit right.
Old Apr 14, 2004 | 09:25 AM
ACDenali's Avatar
What do the beefier servos do for the trannys?
Old Apr 14, 2004 | 09:58 AM
Exclamation servos
to tell you the truth nothing really that my transgo didnt already do...
Old Apr 14, 2004 | 02:18 PM
Flyer's Avatar
They have more fluid area than the stockers. That creats more pressure on the band and makes the band apply quicker (2nd and 4th). It will also have more holding power than the stock ones.
Old Apr 14, 2004 | 02:40 PM
Hit Man X's Avatar
Well if that's the case, something is wrong. My old '99 Z71 had only a TransGo whereas the '01 I have currently shifts MUCH firmer with the billets.
SloSVO
Nov 22, 2020 07:34 PM
Wolftrk99
Dec 3, 2015 08:12 PM
Tigger Welder
Oct 1, 2015 08:41 AM
jtphelps289
Sep 29, 2015 12:00 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
