tranny flush
Old Mar 15, 2003 | 10:19 PM
GREGGO's Avatar
Default Re: tranny flush
If they are on the magnet, trust me, they will not come off. The "filter" is really only a screen. It doesn't always trap contaminates. But the build up on them is broken down with the chemicals used in the flush. AT 46k, I would go ahead and do it. Can't hurt if it is done right.
Greg
Old Mar 15, 2003 | 11:54 PM
graygmc's Avatar
so does the dealer do a good job of flushing the tranny?
Old Mar 16, 2003 | 12:28 AM
GREGGO's Avatar
If you trust your dealer. Mine was not under warranty and warranty doesn't cover it anyway. Few things to make sure of:
1. The type of chemicals that are used are not damaging to the internals.
2. Use tranny pump, not an external pump. Those can overpressure if not set right.
3. how much experience your shop has.
4. Have they ever had returns for new problems after they did the service.
Old Mar 17, 2003 | 08:40 PM
LS1NOVA's Avatar
I work at a GMC/OLDS dealer and we have had some problems with the trans flush machine picking up debris from the bottom of the pan and having it get stuck in the pressure contol solenoid and valve body. If you do have your trans flushed, be sure and change the filter and clean out the pan BEFORE the flush. Not all debris sticks to the magnet(clutch material).
Wolftrk99
Dec 3, 2015 08:12 PM
drummer0415
11
Oct 24, 2015 08:16 PM
sTNT971
Sep 26, 2015 06:27 AM
racedad70
Sep 16, 2015 01:51 PM
mayko
Sep 7, 2015 12:24 PM
