Tranny is acting weird
Old Aug 24, 2004 | 12:24 AM
abbo7's Avatar
Default Tranny is acting weird
I was driving around today and noticed on the 2-3 shift at half-throttle only the rpms jump up before it shifts. At low throttle and full throttle it doesnt do this, only at half-throttle. Has anyone had this problem before?
BTW, this only started after the trans-go was installed, could it be some tuning issue interfering with the trans-go? All my other shifts are very crisp and clean at full/part throttle.
Old Aug 25, 2004 | 12:56 AM
abbo7's Avatar
anyone, have any ideas?
Old Aug 25, 2004 | 01:29 PM
abbo7's Avatar
I doubled checked the fluid and it was a little low from when I did my trans-go install, so I topped it off and hopefully it will help. However, I was talking to my friend with a Lightning and he said ever since he got his tune his will do the same thing on the 2-3 upshift. I will call Allen and see what he thinks about how the tranny is acting and if the tune needs to be tweeked.
Old Aug 25, 2004 | 02:08 PM
L-EATER's Avatar
11 Second Truck Club
A flair at the 2-3 shift is usually caused by the 2-3 feed hole in the separator plate being drilled bigger than .093 I bet you went .110 or whatever the bigger step is. Some trannies can take the big hole, some cant, but it is best to just go .093 on it. Ask me how I know.....
Old Aug 25, 2004 | 02:17 PM
abbo7's Avatar
If thats the point, I dont see how I did that because I made sure not to go above .093 on any hole and on one I only went .082. Did you do the same thing? And if that is the case, what will it do to the tranny in the long run, and can any tuning help correct the problem? Thanks
RustyD
May 23, 2016 07:04 PM
dantheman1540
Feb 24, 2016 09:56 PM
Wolftrk99
Dec 3, 2015 08:12 PM
01silvy
Sep 26, 2015 10:20 PM
sTNT971
Sep 26, 2015 06:27 AM
