tranny ??? 4l80e
so are all the conections as far as wireing the same? i am thinking when i get a tranny i will try to make a 4l80e work. because i do not want to keep rebuilding 4l60e's
Re: tranny ??? 4l80e
No they are not. It takes a few wiring mods and PCM reprogramming to do it. Then it works fine.
No they are not. It takes a few wiring mods and PCM reprogramming to do it. Then it works fine. |
Here's a idea. Get the flash from a 1500HD with a 6.0 and 4L80. Then use edit for the engine... Should work right :confused:
who knows if it will work, i am a little afraid to just try it. someone else try it!!!
i will but not soon enough for you. my plan is well i need money first. but i want to go buy a 4l80e from a wrecked truck or something not spend much. then have it built and eventualy take a weekend to figure out how to make it work. then i will have a 4l60e just chilling in the garage.
You guys ever thought of getting an engine harness from a wrecked 1500HD/2500/2500HD with a 4L80E behind it...
Here's the 4L60E to 4L80E adapter kit we make for $150. It includes the main trans harness adapter as well as the ISS harness which must be added (and the 2 pins plugged into your PCM).
If you have LS1 Edit already you use a 4L80E file with a matching segment #1 ID. If you don't have LS1 Edit we can reprogram your PCM with the 4L80E file. It's actually better if you have Edit, so I don't have to get involved in a bunch of mail order tuning! :D When doing in-shop harnesses we just build the harness for which ever trans is being used by the customer, but this adapter will do the same thing. http://www.imagestation.com/picture/...2/faf66c1d.jpg |
So who is going to be the First to do this swap
i gonna see how long my Built tranny lasts with the current setup If she Gives in I' definatly going the 80 route |
:eek2: :D woooooooohooooo!!!! thats the best news i have heard all day!!! I WILL BE CALLING YOU GUYS!!! where have you been hiding, seems like this question has been asked a few times and that is one of the bigest concerns.
i am soo excited about this, now all i have to do is get the damn thing to bolt in. |
