TR220 112 lsa vs TR220 114 lsa
Old Nov 1, 2005 | 07:24 PM
  #61
La Chochita's Avatar
Sorry about the posts, having trouble with my crazy a$$ computer.
Old Nov 1, 2005 | 07:27 PM
  #62
Sport Side's Avatar
Jerome, just about any cam vendor. Tell them what you want and they should be able to have it cut. If your having troubles deciding what lobes you want, take a look at the cam thread at the top of this form. I think lobes from Comp, Crane, and Cammotion are listed.
Hey Jake, thought this was interesting. I gave cammotion the exact same application list as I had given Ed. Cammotion specs came out being 224/224 .58/.58 114+4 or something to that nature. Can't remember exactly... was a while back.
Old Nov 1, 2005 | 07:51 PM
  #63
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by jerome
so who makes a split pattern cam that is around the 220 range? futral is all too big, the only thunder racing split is 224/227 which i think is also too big, i cant find any comp ones in the same range and crane is the same story.
thanks
jerome
Vinci has one, #066, called the "Stangbanger", specs are 220/224 .551/.551 114. They have it listed on their car cam page, but not the truck page. I actually started a thread asking about it but nobody really had any positive input in reference to it.
Old Nov 2, 2005 | 08:47 AM
  #64
LVSTOGOFST2002's Avatar
totatlly different ideas between the two companies huh?
Old Nov 2, 2005 | 03:06 PM
  #65
Sport Side's Avatar
completely
Old Nov 2, 2005 | 03:45 PM
  #66
budhayes3's Avatar
PT's Slowest Truck
I wanted to throw in another variable that we haven't touched on yet...advance ground in. Seems it's pretty common that alot of the available cams for the GENIII engines have about 4* of advance. If I'm not mistaken, this may have something to do with why there's alot of single pattern grinds...doesn't advancing the cam make it a little exhaust bias?
Old Nov 2, 2005 | 04:10 PM
  #67
02Reaper's Avatar
Originally Posted by bluecajun5.3
anyone know?
With as much timing as allan puts into his tunes you are probably getting the most out of it your gonna get. Either way, if you go any leaner, you will definately have to drop some timing, and if you are planning on spraying, you are gonna have to drop some timing also.
Old Nov 2, 2005 | 04:25 PM
  #68
i disagree, you get it to 12.7 you won't detonate, with the same timing.
Old Nov 2, 2005 | 05:08 PM
  #69
bluecajun5.3's Avatar
11 Second Truck Club
i talked to allen over on ls1truck and he said it's runnin a lil on the rich side. he told me the a/f ratio could be a tad leaner, but where it's at now, i can beat on the truck all day long with no problems.
Old Nov 3, 2005 | 05:56 AM
  #70
02Reaper's Avatar
Timing and fuel can go hand in hand sometimes. I have witnessed this just a few days ago tuning my truck on a loaded mustang dyno. add timing, a/f ratio gets leaner, subtract it, and a/f ratio gets richer. this was also with the wideband in the extra 02 bung just below the header. I dont know what to think about unloaded dynos and the readings they give anymore. All detonation cant be heard by the ear over loud exhaust and noisy valvetrains after modifications.
natejk
Nov 15, 2016 08:05 AM
wickedRCSB
Oct 10, 2015 09:29 PM
shootermwc
Oct 8, 2015 01:45 PM
Jake75
Oct 2, 2015 02:28 PM
bisqikss
Sep 27, 2015 09:40 PM
