In a Toss Up! Help me pick...
Old Jan 16, 2012 | 06:52 PM
Sn0wBa11's Avatar
11 Second Truck Club
Default In a Toss Up! Help me pick...
As soon as I get my 243 heads back from the machine shop I can finish putting my 6.0 (lq4) together and put it in the truck but I'm stuck on which cam I want to use. I've narrowed it down to 3 different cams but I'm having a hard time deciding so I'm gonna ask you experienced guys for your opinions so lemme hear them!
Here's the 3 cams I'm stuck on:
1) Comp Ls-R 219/227 607/614 112 lsa (my current cam) I know it's mild for a 6.0 but I think it'd be pretty peppy
2) Comp 224/230 581/592 110 lsa
3) TSP Torquer v2 232/234 595/598 112 lsa
Keep in mind Im on a 3200 stall converter and dont wanna change it. Also running a 3.73 rear gear and 150 wet shot.
Old Jan 16, 2012 | 07:05 PM
2000chevysilverado's Avatar
I had the third one in my gto talk about good all around rpms with a m6
Old Jan 16, 2012 | 09:11 PM
f4tal's Avatar
I'd say 224/230... the stall will work better with it and the NX will love the bigger split.
Old Jan 16, 2012 | 09:39 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
2nd one IMO i have a LQ4 in my truck with milled ported 243s and im running a 226/230 600/600 111lsa
Old Jan 17, 2012 | 12:27 PM
06Sierra2's Avatar
another vote for the 2nd one
Old Jan 17, 2012 | 09:45 PM
LS1TRUCKGUY's Avatar
is your LQ4 going to be stock displacement? what all are you having done to the 243's? what does your converter flash to behind the 4.8? the higher lift of the LS-R and the torquer v2 will work well with ported heads, and IMO a 3200 stall will be ok with the tourqer in a 6.0
my first choice is #1
second choice is #3
Old Jan 17, 2012 | 10:01 PM
ltr450ryder's Avatar
2nd one for the stall I would do the 3rd one if it was me tho lol
Old Jan 17, 2012 | 10:03 PM
There also is the street sweeper ht cam which is a 282/232 I don't remember the lift I know its on a 111lsa
Old Jan 17, 2012 | 10:12 PM
Sn0wBa11's Avatar
Stock displacement lq4 and the 243 are stock other than a good valve job, surface and patriot gold springs
My converter flashes at 3000
Old Jan 18, 2012 | 09:08 PM
i vote #1... as i said adove, the lift will take advantage of the 243's not to mention the nitrous will love the split in duration
