Tis is a good cam?
Hey guys im in a progress to buy a cam for my 4.8, just wanted to ask if this is a good cam for it, the truck has a some bolt ons and 3.73 with a 2600 stall.
This is the cam specs...
XFI Hydraulic Roller Camshaft
GM Gen III (LS1, -2, -6)
Adv. Duration: 273° Int/279° Exh
Duration @ .050: 224° Int/230° Exh
Lift: .581'' Int/.588'' Exh
RPM Range: 2000-7000
Lobe Sep: 113°
Lobe Sep: 113°
I wouldnt be scared to run something in the low 220 range with that stall. however you will see better performance with that 212/218 your looking at! There is a dyno sheet of the 265 which is the low lift comp cam version of the 212/218. It put up some big numbers, look at the top of this section for the chart
