timing chain
Old Jun 30, 2009 | 02:59 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Default timing chain
well im going to be doing a cam swap in my truck very soon so should i replace the chain my truck has 55k on it and if i do i was thinking of doing a ls2
Old Jun 30, 2009 | 04:22 PM
anybody
Old Jun 30, 2009 | 05:06 PM
hirdlej's Avatar
Don't bother putting a new chain on unless you put a decent one on.
Old Jun 30, 2009 | 06:00 PM
thats kinda what i figured since i hear these motors are a real PITA to get the chains off
Old Jun 30, 2009 | 06:38 PM
terravast4's Avatar
I used the ls2 hd chain. I figured since I was already in there at 55,000 miles.
Old Jun 30, 2009 | 07:21 PM
hirdlej's Avatar
The LS2 chain isn't any better than your stocker. It's just as sloppy. If you're going to get a new chain, get it as a matched set with NEW SPROCKETS and get a decent brand as well. Like a ProGear.
Old Jun 30, 2009 | 07:22 PM
hirdlej's Avatar
Old Jun 30, 2009 | 07:23 PM
hirdlej's Avatar
It's not so bad changing the chains and sprockets out. you need to drop the pan though to get at the oil pump pickup tube. Just time consuming that's all.
Old Jun 30, 2009 | 08:28 PM
i heard also if you do a double roller you have to notch out the timing cover correct me if im wrong
Old Jun 30, 2009 | 09:11 PM
hirdlej's Avatar
You don't need a double roller, you just need A NICE accurate matched set if you're going to go through the hassle of changing chains. The LS2 chain upgrade is a waste IMO.
