Throttle body help
IMO, unless you're really moving some air with a cam/heads/intake you don't need a p&p tb. You just can't really port the stock tb that much. Just save your pennies for a 90mm conversion.
yeah, this is total BS from their ebay listing:
What can I expect and How Much?
· Crisper throttle response, better low end, and higher rev potential
· Will handle 400+ cu-in motors up to 7000rpm+ at 550hp
· 10-15hp on a stock motor – much greater throttle response and torque
· 50-100hp w/ cam and mild head work - i.e. valves & hand port (over stock throttle body)
· 100hp+ on hot 400ci and larger motors
Easy to install in about 1/2 hour with no other modifications or engine upgrades required - including the intake.
****, if I could get 10-15 hp for 200 bux I woulda done it a LONG time ago.
SlvrSierra4.8
Oct 1, 2015 09:39 PM
99bluefirebird
Sep 17, 2015 08:05 PM
