throttle body compatability question
Old Dec 17, 2010 | 10:51 PM
devink's Avatar
Default throttle body compatability question
What's the difference between and electronic TB vs. a drive by wire? What steps are required to adapt an electronic to an '05 silerado w/ 5.3?
Thanks
Old Dec 18, 2010 | 01:27 AM
Blown06's Avatar
8 Second Truck Club
I thought the 05's had dbw tb's. Didn't that start in 04?
If you looking to convert your 05 to dbc (drive-by-cable), you would have to get the tb/iac, linkage, pedal, and do some rewiring to the pcm. Then you might have to convert to an older pcm as I'm not sure the later ones have the internal hardware to do such a thing. I looked into it a while back and could not find a whole lot of info, and with the advancements being made by torque rush, I could hardly justify it. I'm sticking with DBW for now.
Old Dec 18, 2010 | 08:20 AM
devink's Avatar
Default I do have DBW
The reason for my question is that I was looking to purchase an intake with an electronic TB and was told by the seller that electronic and DBW were not the same. Is this true?
Old Dec 18, 2010 | 08:33 AM
RibeiroBJJ's Avatar
Praise The Lowered
NOT true, they are the "same" ... IIRC all you have to do is swap your fuel rails over to a returnless system..and maybe re-arange a wire or hose..But not convert to dbc/dbw
Old Dec 19, 2010 | 12:28 AM
devink's Avatar
good to know thanks for the clarification.
jdb11386
Dec 3, 2015 09:34 PM
TimDave217
Aug 24, 2015 04:38 PM
Slammed96
Jul 27, 2015 07:22 AM
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
